SELECT data_key, data_value
FROM xf_data_registry
Run Time: 0.000204
SELECT session_data
FROM xf_session
WHERE session_id = ?
AND expiry_date >= ?
Params: 70e4241a96581f1e8d8c599afcfc4f6b, 1716835974
Run Time: 0.000198
SIMPLE | xf_session | const | PRIMARY,expiry_date | PRIMARY | 34 | const | 1 | |
SELECT cache_value
Params: 1
Run Time: 0.000099
SELECT profile_post.*
posting_user.*,
IF(posting_user.username IS NULL, profile_post.username, posting_user.username) AS username,
receiving_user.username
AS profile_username,
receiving_user.gender
AS profile_gender,
receiving_user.user_state
AS profile_user_state,
receiving_user.user_group_id
AS profile_user_group_id,
receiving_user.secondary_group_ids
AS profile_secondary_group_ids,
receiving_user.display_style_group_id
AS profile_display_style_group_id,
receiving_user.is_banned
AS profile_is_banned,
receiving_user.is_admin
AS profile_is_admin,
receiving_user.is_moderator
AS profile_is_moderator,
receiving_user.avatar_date
AS profile_avatar_date,
receiving_user.gravatar
AS profile_gravatar,
receiving_user.warning_points
AS profile_warning_points,
receiving_user.permission_combination_id
AS profile_permission_combination_id,
receiving_user_privacy.allow_view_profile
AS profile_allow_view_profile,
receiving_user_privacy.allow_post_profile
AS profile_allow_post_profile,
receiving_user_privacy.allow_send_personal_conversation
AS profile_allow_send_personal_conversation,
receiving_user_privacy.allow_view_identities
AS profile_allow_view_identities,
receiving_user_privacy.allow_receive_news_feed
AS profile_allow_allow_receive_news_feed,
IF (receiving_user_follow.follow_user_id, 1, 0)
AS following_0
FROM xf_profile_post AS profile_post
LEFT JOIN xf_user AS posting_user ON
(posting_user.user_id = profile_post.user_id)
LEFT JOIN xf_user AS receiving_user ON
(receiving_user.user_id = profile_post.profile_user_id)
LEFT JOIN xf_user_privacy AS receiving_user_privacy ON
(receiving_user_privacy.user_id = profile_post.profile_user_id)
LEFT JOIN xf_user_follow AS receiving_user_follow ON
(receiving_user_follow.user_id = profile_post.profile_user_id AND follow_user_id = 0)
WHERE (profile_post.message_state IN ('visible'))
ORDER BY profile_post.post_date DESC
LIMIT 10
Run Time: 0.000383
SIMPLE | profile_post | index | | post_date | 4 | | 10 | Using where |
SIMPLE | posting_user | eq_ref | PRIMARY | PRIMARY | 4 | poloclub.profile_post.user_id | 1 | |
SIMPLE | receiving_user | eq_ref | PRIMARY | PRIMARY | 4 | poloclub.profile_post.profile_user_id | 1 | |
SIMPLE | receiving_user_privacy | eq_ref | PRIMARY | PRIMARY | 4 | poloclub.profile_post.profile_user_id | 1 | |
SIMPLE | receiving_user_follow | eq_ref | PRIMARY,follow_user_id | PRIMARY | 8 | poloclub.profile_post.profile_user_id,const | 1 | Using index |
SELECT *
FROM xf_node
WHERE display_in_list = 1
ORDER BY lft ASC
Run Time: 0.000137
SIMPLE | xf_node | ALL | display_in_list | | | | 53 | Using where; Using filesort |
SELECT content_id, cache_value
FROM xf_permission_cache_content
AND content_type = 'node'
Params: 1
Run Time: 0.000080
SIMPLE | xf_permission_cache_content | ref | PRIMARY | PRIMARY | 31 | const,const | 77 | Using where |
SELECT forum.*
NULL AS forum_read_date
FROM xf_forum AS forum
WHERE forum.node_id IN (11, 12, 13, 44, 14, 15, 41, 47, 67, 16, 17, 48, 18, 19, 20, 32, 21, 72, 43, 22, 23, 24, 76, 33, 71, 34, 35, 36, 38, 37, 39, 40, 70, 30, 31, 25, 68, 42, 45, 65, 66, 46, 51, 52, 53, 54, 60, 55, 56, 57, 58, 59, 61, 64, 62, 63, 49, 50, 82, 26, 28, 77, 78, 79, 80, 81, 27, 29)
Run Time: 0.000187
SIMPLE | node | index | PRIMARY | parent_node_id | 4 | | 53 | Using where; Using index |
SIMPLE | forum | eq_ref | PRIMARY | PRIMARY | 4 | poloclub.node.node_id | 1 | |
SELECT session_activity.*
user.*
LEFT JOIN xf_user AS user ON
WHERE (session_activity.view_date > 1716835074)
Run Time: 0.000571
SIMPLE | session_activity | range | view_date | view_date | 4 | | 27 | Using where |
SELECT data_value
WHERE data_key = ?
Params: boardTotals
Run Time: 0.000054
UPDATE `xf_session` SET `expiry_date` = ?, `session_data` = ? WHERE (session_id = '70e4241a96581f1e8d8c599afcfc4f6b')
Params: 1716839574,
Run Time: 0.065773
VALUES
ON DUPLICATE KEY UPDATE
ip = VALUES(ip),
params = VALUES(params),
robot_key = VALUES(robot_key)
Params: 0, , , XenForo_ControllerPublic_Forum, Index, valid, node_name=, 1716835974,
Run Time: 0.000147
WHERE data_key IN ('wfc__1_forum_list')
Run Time: 0.000092
